markdj
On a Princess 37 there is an old Cetrek autopilot which is attached to the steering with a cable that goes into a steering column that is attached to a motor with a chain drive.
When the autopilot is not in use the shaft of the motor can turn so as to allow manual steering but when the drive is engaged an electro-magnet is engaged that pulls a clutch plate which holds against a bearing with a friction type/brake pad which should hold the clutch plate in place to prevent slippage so to allow the motor to turn the steering.
The electromagnet seems to have lost its strength and the drive is slipping. The magnet is made by Eaton.
A new cable drive is £900 so I was hoping to avoid replacement. I have tried replacing the brake pad with a new one as the old one was well worn but this has not helped increase the friction to allow the drive to work without slipping.
Does anyone know where I could get a magnet for this or have one lying around ?
The drive unit is a 402/12v
