runner911
Active Member
Suffered quite badly this year with the anodes on my Merry Fisher 655 fizzing off in a few months as a result of which the engine and prop. shaft water intakes "de-zincified" and will have to be replaced.
I will be bonding all the new skin fittings ( bronze as opposed to brass ) and valves to the main anode on the transom of the boat.
However I am having another large anode fitted on the bottom of the boat near the prop.shaft with a view to running an earth wire from the anode up to an Electro Eliminator marketed by MG Duff. The kit has arrived , but I can't see how I can fit it anywhere so that the brushes rest on the prop shaft inside the boat near the gearbox.
Anyone ever fitted such a device ? If so , did you have to make up some sort of frame to support the arms of the brushes ?
