Electrics
muchy_
3 Apr 2002
Stalham, Norfolk (boat)
I have a dual battery system, you know small one for starting and two big ones for everything else. These are divided by a split charge diode. Is it possible to disconnect one bank or the other while the engine is running without frying the alternator?
BrendanS
11 Jun 2002
Tesla in Space
There are a few people on this forum who are technically literate /forums/images/icons/wink.gif and hopefully you'll receive a response.
However, if you post this in the PBO forum, you'll probably receive a far higher response, as that is where all the people who are knowledgeable in this sort of thing tend to post.
Col
14 Oct 2001
Berks
So long as you have a battery connected, you'll be OK. Make sure the alt is not subjected to a "no load" situation during switching.
<hr width=100% size=1><A target="_blank" HREF=http://www.arweb.co.uk/argallery/colspics> Cols Picture Album</A>
DavidJ
15 Jun 2001
Agree with Col. If no battery then the alternator seeks infinite charge and will quickly blow the diodes. I've seen car drivers swop batteries over while the car is running (tickover) so the alternator has some tolerance but don't go there in my opinion.
David
tr7v8
30 Nov 2001
Kent
Shouldn't be a problem with one reservation if one bank is very flat and the other pretty well charged you could cause a surge which the regulator may take offence at. Also ensuring the live lead doesn't short out is quite important.
Jim
