cliffb
I'm confused. The boat is a 2002 Beneteau 36CC. Whilst delving about in the engine room in a quest to see how to fit a second domestic battery I found something ODD, (or so it seemed to me). FYI, there's three battery main switches. One Neutral (black), one Engine Start (Red) and one Service (Red). The odd thing is that there's a great big electrical strap between the the two red switches. Which accounts for the reason why, on the occassion of forgetting to turn on the 'Engine' start switch, I have started the engine; presumably from the service battery.
Now, to me, this seems nonsense. What's the point of having two batteries, and two switches if they're strapped together. It is clearly a Beneteau factory fitted item and there must be a reason for it... I suppose. I'm tempted to take the strap off, but my concern is that the engine alternator may not charge one or other of the batteries (not knowing how this charging circuit is typically set-up).
So....
The question for the panel is....would you take off the strap? If so, is it likely to effect the battery charging circuit?
And whilst asking questions...
If I put in a second service battery, does this have any bearing on the shore-power charger and its ability to charge two batteries instead of one...or more accurately, three batteries instead of two?
As always, any advice/help much appreciated.
So....
