Electrics Help required Nmea connection
ians
22 Oct 2001
up north
Good Afternoon All
Need some advice, current set up is Furuno 1650W Gps Plotter linked to St7000 autopilot and also linked to Furuno radar via the nmea cable.
Just invested in a Simrad RS87 DSC radio so need the nmea connection for this aswell.
Am I overloading the system and should I invest in a nmea buffer or will the system be ok.
Any advice appreciated
regards
ians
Stephen
Mine at the moment are just connected together in a block, I may go down the route of a proper junction box
ians
So long as they're effectively connected in parallel it probably won't matter if you fan out the connections from the GPS or "daisy chain" them. A daisy chain may reduce the amount of cable required. A fan-out is easier to fault find on if things don't work.
