tomtom393
New Member
I will try and keep this short - I am having some problems with the Amp Meter that we have located on the boats electrical switchboard.
I believe from memory that it reads -75 to +75 - when we start the engine and run it for a few minutes with lets say the navigational aids running it shows + 10 amps which I reckon to be rights given the draw of power versus the alternator work of charging the batteries. Now here is the strange part; every so often the Amp meter will jump to +75 amps and stay glued to the end stop for 5 minutes or so and then return to normal - is this normal??
I have a three battery set up 1x starter (new) 2 x Domestic (new) they are rated at 115 Amp hours and are specfic to the job in hand -
The yacht electrical system is beyond my knowledge but I believe that we have a battery management system and a separate show power charger for when we are connected to 220Volts... At present I think we have a problem with the charger for shore power but not sure they are linked.
Can someone give me some pointers!!!
