BobE
I've a Bukh 24..
Found that the Temprature alarm light had failed (filament gone and also connecting wires to spade teminal)..
Now I find that the damn thing is wired in series with the acoustic buzzer so don't know if there was an overheat problem...
Had to buy a set of bulbs. (Not sold separately) Over £ 30 !!!
New bulbs show 25 to 27 ohms on my meter as against the two remaining old ones at 16 ohms.
So when one switches on the motor the red ( Charging) and yellow ( Oil pressure) come on and I can tell if the bulbs are OK....
But the temperature one never comes on because the temp sender doesn't "make to earth" until the temp limit is exceeded.. and if the bulb/lamp fails I'll never know!!!
So what if I simply join the two spades at the back of the lamp and if the temp gets high then at least the buzzer will sound even if the lamp has failed...
I could of course run a second wire direct from the sender to the buzzer...
Is there any point in the extra length of wire?
Do I need to put some sort of resistance in the direct line to get the lamp as well as the buzzer to work??
Any electrical gurus out there to advise please??
BTW Bukh suggest that one should check the thing annually by shorting out the sender with the engine running.
A Happy, if belated, New Year to you all..
Cheers Bob E...
Cheers Bob E...
