StephenW
Salvaged a rib-type (1.2m'ish ) vhf aerial from a marina waste skip with thought of it providing a useful emergency aerial if the main aerial in the mast is ever lost for any reason. Only apparent damage was a broken plastic mount, short length (15cm) of cable attached.
Have bought a connection and suitable cable but when assembled & tested there is continuity between inner and outer connections.
Unsure whether there should be or not???
Basic arrangement is aerial with short length of its own wire, joint , then URM 76 Low C cable connected to UHF plug for VHF radio.
I've broken the connection joint (OK, I should have tested before finally joining) and there is no continuity between outer sheath and core in the new cable and UHF connector at the radio end.
However, the short aerial cable connected to the aerial has continuity between inner and outer cable - should this be so?
Shooting in the dark a bit here so appreciate feedback from anyone with good electrical knowledge.
r
r
