oldsaltoz
Connecting shower pump, soldering the joints with a 240 volt iron, noticed a small spark on the negative terminal, and pump runs when soldering contacts the positive terminal, 12 volt power turned on at the time, float switch is in line before the pump connection.
Put a meter between the 240 volt iron and the positive side of the pump and got 12vDC. but nothing with the iron turned off.
We have a 3 stage battery charging and battery monitoring systems on board as well as shore power and 3 solar panels, also twin engines.
Any idea what we should be looking for?
