Sailingsaves
I was recommended to buy an in-line rcd similar to this one some time ago (I bought 2 actually):
http://cpc.farnell.com/jojo/521935/rcd-unit-in-line/dp/PL02597
I noticed the base was getting hot. The second one was getting even hotter, so I stopped using it.
Today it failed - see photos.
The fuse in the 13A plug had failed (I had a 2A fuse in there), but upon taking it apart I can see that the circuit board had over heated and the 100 ohm resistor has failed.
Any ideas what is going on? Can I just replace the resistor do you think? But why the heating issue?View attachment 50279View attachment 50278View attachment 50277View attachment 50276
Not sure how long cpc warranty is, but it is over one year old. It was connected to large paddling pool pump last summer with no problem.
Contralube 770 inside has spit and spat around the inside a bit.
