bluedragon
I’d welcome a few thoughts on this topic. The yacht is 27ft, a good but old diesel with new Dynastart, usual instruments, GPS, cockpit plotter, usual lights, tiller pilot, VHF…no coolboxes, PCs or the like. I have one engine-start battery around 60Ah and one service battery 75Ah. The Dynastart puts out around 12-15A at best.
For day sailing or nights in marinas, my charging capability vs. amp hours used is fine. But this year I’m planning to do some extensive cruising from the Bristol Channel to Scillies to Ireland to N.Wales (at least that’s the plan!). I could be at sea for up to 48 hrs, and even shorter passages may often end at anchor. That means most instruments on most of the time, nav. lights, extended use of the tiller pilot, etc.
I’ve worked out a number of typical energy demand scenarios for different types of passage and come up with between 35 and 65 Ah over a 24 hr period. To replenish this I’d need to run my engine between say 3-6 hrs per day…not something I want to be forced to do. So I need some additional power generation. I’d rather avoid fitting an alternator for a number of reasons, and would probably still have to run the engine for no other reason than charging. I’m therefore thinking of alternatives. These seem to be:
a) Wind generator: attractive but I’d probably need at least 1.5-2.0A output on average with a typical summer wind speeds to help make up my shortfall. I already have a small Forgen 500, which is fine for keeping full batteries topped-up, but useless for the above purpose. The bigger Rutland and Aerogen types will make my boat (27ft) look like a helicopter flying sideways!!..won’t they??
b) Solar panels: nice idea, but off the coasts of the western U.K. are these a realistic proposition??
c) Petrol generator: perhaps, but noise / size / storage / cost for the good ones?? Is this a viable option in the circumstances?
d) Just take extra topped-up service batteries and recharge all using marina shore power when available. Simple and attractive idea, but it does mean visits to marinas every few days or so.
So…sorry for the long post…but I would like some comments from members who have faced and solved a similar dilemma. Many thanks.
