landyhubbard
Advice please. My pulpit-mounted navigation light is not working. I have checked the bulb and its OK, and I have voltage at the pins of the lamp-holder according to the multi-meter and I have cleaned the base of the bulb and the pins, but still can't get the light to work. I have swaped the bulb-holder fior a spare, still no joy. The only thing that I can see that might be a problem is that the wire to the lamp is pretty black, even when cut well back, but I have cleaned the ends well. Could the multi-meter be reading voltage but with a problem further upstream that is causing a malfunction? I am steeling myself to replace the wireing back to the switchboard, a hell of a job as it runs through the deck and up inside the pulpit.
