scubaman
I've always struggled with oil change on our KAMD300's (and KAD42 before that). I've tried several manual pumps, including vacuum ones, but never had a very successful oil change, so I've decided that something new has to be tried. The biggest problem is getting enough oil out and the whole process taking too much time.
I had a chat with a local Volvo engineer who suggested an electric Volvo pump. I believe it's this. His comment went along the lines "like opening a tap" (referring to the rate at which the oil comes out).
Has anyone tried this? As far as I can tell, the hose is clamped into the dipstick tube, which presumably reaches to bottom of the oil pan to get as much oil out as needed. The pumps I've used so far have had a separate hose that goes inside the dipstick tube.
Any comments welcome.
Thanks!
Thanks!
