Electric powered furling
[2574]
29 Nov 2002
I'd appreciate some views on powered furling of sails. We've been looking at a yacht that we are pretty keen on but I am concerned that she has powered mainsail and genoa furling. It seems to me that putting an electric motor on the bow of a yacht where it gets soaked in saltwater every minute and expecting it to last beyond five minutes is a bit optimistic. Likewise on mainsail, albeit slightly less exposed where the motor is mounted on the mast.
Firstly - has anyone any experience of this type of kit and is it any good?
Secondly - does anyone know if it is a big/expensive job to convert back to manual and do away with the motors?
TIA
Rob
Talbot
23 Aug 2003
Brighton, UK
I would certainly be happier if it was hydraulic. It has presumably been powered because it is considered to be too much for human power.
[2574]
29 Nov 2002
Yes, it's a 13m yacht (17 tonnes), and the present owner who is now 67 has I think found it a bit too much
bruce
26 May 2004
florida USA
best place to start is with the people that make the equipment, then ask specific questions here. several LONG discussions on main furling in last 2 weeks . pers. haven't seen electric jib furlers anywhere.
Alex_Blackwood
19 May 2003
Fareham
Hi, A couple of points. You say it is a bit optimistic to expect the electrics to last more than five minutes where they get soaked every minute. I take your point and tend to agree but have you asked how long they have been there? They must have been installed for some time, no reason why a well designed bit of kit shouldn't last. Good idea to check with the manufacturer though.
The other thing I would be interested in is, can you disengage the beast and furl by hand if it all goes wrong.
A question of my own. I know a bit about electrics, electronics and general things about boats, ships and sealing wax. However what is the difference, if any, between roller reefing and roller furling?
[2574]
29 Nov 2002
Alex,
Yes if the genoa drive was to fail it is possible to put a winch handle in gearbox/motor unit and wind manually. The access is on the bow side of the unit and I just imagined standing there trying to furl in a F7 being submerged below a wave every 30 seconds. Not much fun.
The boat is French and they use the expression "furling gearbox" so I'd rather followed on. It amounts to the same thing.
tugboat
1 May 2004
Devon
Hi Alex. Roller furling gear allows only that the sail is fully deployed or completely rolled away - an example being the Wickham Martin furling gear where the sail was rolled around a wire luff. Roller reefing uses a foil (usually alloy) and allows the sail to be rolled away in stages so that it can be used in a reduced size as the wind increases. Hope that helps.
