Electric Outboard Speed (or lack of!)
Andrewdfree
New Member
2 Apr 2009
Hi all,
I'm looking at getting a 50lbs electric outboard as a backup for my boat, and I was just wandering if anyone knows roughly how fast it would push my boat. The boat is a 14ft planing V-hull, and it weighs about 250kg. I know it won't be fast, but I only do canal cruising (for now), so I can only go at 4mph max :D
PS. I don't want to consider a small outboard, as I already have one, I just want an electric one for some peace and quiet every now and then :)
Hi all,
http://www.ybw.com/forums/showthread.php?356846-3-3-two-stroke&p=4140796#post4140796
have his hand off
its a snip, forget battery motors a total waste of money
I have a smallish (30 lbf?) Minn Kota which I use in an inflatable tender. Not fast, but works OK and is silent. I would have thought that a bigger one like you are thinking of would be fine.
We've done a good number of miles with a 38lb MinnKota pushing a fully laden 17' canoe. It would do 3 to 4 mph Ok on canals. We used to get about 16 miles range from 120 AHr (12 volt), if we kept speed down to 3 mph max. If you go to 4 mph range would drop to (guess) 5 miles.
Torqeedo = lots more miles per AHr, but they're not silent - quite a significant whine. Highly recommend Minn Kota type for silent canal cruising.
I use a 56lb thrust Wavehopper Stowaway outboard for manoeuvring in and around the launch areas at Rutland. It pushes my 20' Medina along OK but I couldn't estimate top end or range on the 12v battery. It did bring us back a couple of miles when we were becalmed one day last year.
Plenty of suggestions there but I would suggest that with a few modifications you might be able to fit decent oars and rowlocks with less cost more reliability. good luck olewill
See post #3. OP does not want to spend that kind of money.
A Trolling motor such as a MinnKota will do the job, but these are not cheap compared with an outboard and limited capacity. They are designed to move fishing platforms short distances in American lakes - not the same as cruising canals in a speedboat!
Hi sailorman,
"total waste of money" - doesn't this view depend on what the buyer wants? I bought a Torqeedo and it's been a great success, meeting every criteria I was looking for. OK, more money than a petrol outboard but then boating is boating, and what appears a waste of money to some is worth its weight in gold to others.
Having had petrol outboards for over 20 years, I was fed up with their weight, their smell, their temperamental starting issues, and storing the fuel. Instead, the Torqeedo provided a lightweight solution, no smell, no staring issues, no fuel storage issues, no servicing - to me, well worth the extra.
You forgot to mention the weight & limited capacity of the battery.
Also how does your motor fair in strong tidal flows
The Torqeedo with the Torqeedo solar panel will be perfect for the job. See the video in post #2.
BUT the OP doesn't want to spend the money.
50lb thrust will push a 14ft hull at 4 knots no problem, if the hull shape is reasonable and it is not dragging its transom.
Provided it is flat water and not into a headwind.
Also provided the prop pitch is right.
So as an "all rounder", no good then
FFS - the OP already HAS a conventional motor - cruising the canals can be nicer if done in silence - so either a 50Lbs electric motor will push his boat or it won't ...
Surely the pertinent questions are
1) Will it push his boat at max 4mph
2) how long will a 120Ah battery push his boat for at different speeds
Opinions on which petrol outboard he should get are therefore superfluous ...
+1.
There have been electric boats on inland waters for a very long time.
Most tend to have longer waterlines than 14ft, to keep the resistance down.
The OPs boat is a planing deep V so basically unsuitable for low speed work. The Trolling motor will move it at 4mph but doubt he will have much control over direction!
Not really relevant to the OPs question - which was whether an electric motor would move his boat - which I think it would. It would be equally uncontrollable with a small outboard.
