neil1967
Following on from the series of fuel/filter questions posed by pcatteral, has anyone replaced a mechanical lift pump with an electric one - i know oldsalt has, but would like to hear of any other experiences. The background to my question is that the diesel tank on my yacht is lower than the engine (Perkins 4108) and bleeding it can be a pain. I am going to replace the primary filter with a racor this winter and am considering fitting an electric lift pump immediately after the racor, and then bypassing the mechanical pump entirely.
I believe that the benefit will be easier bleeding (no need to turn the engine over and risk salt water suck back) and oldsalt reckons starting is easier too. Equally, if I leave the mechanical lift pump in place, I will have a fallback should the electric one fail (although if it is solid state there is no reason why it should - in fact it should be more reliable than the mechanical pump). Can any one see any problem with this approach, and can I just blank off the existing lift pump fittings, or would I need to actually remove it?
Neil
Neil
