Graham_Wright
I have fitted one of these to each tank;-
12V General Electronic Fuel Pump, Car Modified Car Fuel Pump Gasoline Pump J9X1 | eBay
They pick up via a coarse filter in the tank and feed the main engine filters in the engine bay. The tanks are lower than the engine.
The fuel system also feeds the diesel heaters.
The in-tank filter is quite coarse and the pump interior valve regularly becomes blocked. The pump is supplied with a filter (and no instructions as usual) which I suppose should be fitted before the pump. The filters I have are sealed. Although the pumps can be dismantled, the mechanism is fiddly.
I have purchased one of these;-
Low pressure SU replacement carburettor Fuelflow 12v electronic fuel pump 15LM12 | eBay
and look forward to improvement.
Any observations?
Any observations?
