Rob_Webb
Got a small (500 gph) electric pump under the shower tray in the heads to remove water during a shower. Operates via float switch. When activated it starts at full speed then sounds as though it's labouring and slows down until it nearly stops. Also burns out 10A fuse in fusebox if I let it.
Have removed it and tried to remove any gunge and unit appears to be clean-ish. But even with no load (i.e. out of the water) it behaves the same. Don't believe it's a batter supply problem.
Any ideas?
Any ideas?
