nimrod1230
Anyone used one of these? any good or too slow and power hungry?
Two choices when it comes to pumps:
- spend £70 on a LVM which will do the job all in one go.
- spend £5 on a cheapo pump which will do most of the work, then use the foot pump to do the last ten strokes or so and finish it off.
Personally I was quite willing to save £65!
So not a straight forward problem. The dinghy is 5 compartments with high pressure keel so the worst case possible it seems. The idea of dragging the dinghy out of a locker and inflating effort free in minutes sounds good but from what has been said is not going to happen. Back to the drawing board or at least working out a stowage arrangement on the stern as on the previous boat. Thanks for the replies.
Seriously though, are electric pumps worth the money. The answer has to be no, unless you find manual pumps so exhausting you cant row the dinghy for some time after pumping it up..
So not a straight forward problem. The dinghy is 5 compartments with high pressure keel so the worst case possible it seems. The idea of dragging the dinghy out of a locker and inflating effort free in minutes sounds good but from what has been said is not going to happen. .
I use a high speed electric pump. It can't be run via a 12volt 'ligter' type socket as the wiring probably isn't up to it, so it has to be connected to a battery.
I connect mine to a booster battery pack, which I use as an emergency starter battery pack. I've never used it (the battery pack) for my boat, but I have started the odd Mobo with it.
It works very well and inflates my dinghy in about 2 minutes, just like it says.
I've also used it to inflste the sponsons on RIBs even though I coudn't get an air tight fit at the valve.
