whipper_snapper
What happens if you connect a depth sounder to an incompatible transducer ? Do you get no reading, wrong reading, reduced range or some other symptom?
The reason for asking is that we have a NASA Target depth gauge that gives very accurate readings in very shallow water, but looses the bottom at depths over 10m. This makes it pretty much useless for the sort of sailing we do.
The PO said the reason was that the transducer was for a different device (an old whirling LED thing) and provided the 'proper' transducer in a carrier bag. However, we have since discovered multiple reasons to doubt the sanity of the PO.
Before we mess around cutting holes in the boat, can anyone confirm that accurate readings but very poor range is likely to result from such a mismatch ? My understanding is that there are only two possible frequencies and I would not expect it to work at all with a sender at the wrong frequency, and would be even more surprised if it was accurate.
A complication is that the very steep V profile makes it hard to try it out fitted internally and firing through the hull.
