D
Deleted member 36384
Hello,
The water in my stainless tanks has become tainted. I have drained down, vacuumed out crud, sprayed and soaked the walls, floors and ceilings with 5ml per gallon of water / household bleach. I then vacuumed out agains and filled with 100 ml of bleach in each 60 gallon tank, and pumped through to taps. The water and bleach solution has been soaking since Thursday and today I will drain down and flush through with fresh water before filling again only with fresh water.
I noticed that the welds on the inside of the stainless tanks are slightly discoloured, rust like, but on the surface, not flaky like you would see on plain steel. The welds on the outside of the tank are stainless with no discolouration. Do you think that the household bleach solution will have an effect on the welds at this concentration and soak period, 4 days? I am aware that there could be a reaction due to the chlorine but no idea if it is vigorous at these concentrations. I don't think it is but all the Youtube / Google stuff suggests 12 hour soak periods. Is it possible that even with flushing out, that the welds could retain bleach and form pin holes over time, or is that just ridiculous over this time frame and the fact that 60 gallons of fresh water will likely dilute to the point of irrelevance.
Any information appreciated.
Thanks,
BlowingOldBoots
Thanks,
BlowingOldBoots
