Jokani
The manual says to lubricate the pedestal shaft bearings with 'Teflon Part No 827' grease, squeezing in in to the holes on top of the bearing housings. I cannot find this grease available in the UK, is there a suitable alternative? I have some 'SUPER LUBE 85G 2105011 By LOCTITE' onboard for other uses, would that be suitable?
The roller chain, the manual says use #30 oil, but I have seen elsewhere that something like this spray 'Wurth High Performance Dry Chain Lube', is both better and easier to apply. Thoughts?
Again, oil the wire and sheeves or dry lube spay?
TIA
TIA
