Can running an echo sounder with no oil in the oil bath damage the system (it's an Incastec combined log and sounder, with separate transducers and one display, probably about 10-15 years old)?
A constant alarm tone was sounding every time I switched it on after getting back on the oggin after a lay-up of about four years, then I discovered all the oil had gone, but putting more oil in hasn't solved the problem. Also, the transducer head is a pretty tight fit in its well; although the sounder worked before, I've been told there should be plenty of room.
Any advice greatly appreciated
