pcatterall
Eberspacher heaters and particularly the D2 and D4 Airtronic have been a bit of a retirement hobby for me.
I have very little experience, though, in setting them up with an external thermostat.
I am often asked about it though and having found an Eberspacher external thermostat decided to investigate.
In the 'normal' set up the red/slate lead provides the positive heat setting connection and the brown/white lead is the return for that.
The external thermostat uses the Eberspachers grey lead and on the diagram I have uses a spur from the brown white lead for the return.
The diagram does not indicate if the red/slate remains in place though I guess it does in order for the heat setting control to function?
I guess ( again) that the ECU senses the connection of the grey lead and starts to use the external thermostat rather than the 'internal' one ?
Can anyone offer an experienced based view on this before I start to test my theory?
During my examination of some circuit diagrams in respect of the above I came across one showing a switch between the red/slate and the brown/white leads and this was called 'fan only switch' This was interesting on 2 counts..... One was that I suppose we could wire in a switch which would just circulate air ( cool air if the air inlet duct was in a cool area).
Two because I have had several ECU failures where the ECU has reverted to a 'fan only' mode, in these situations I found that I could get the heater to start and heat by removing the red/slate and the brown/white leads from the circuit, there was of course then no control on the heat level but I now wonder if an external thermostat would allow these otherwise good ECUs to work?
Possibly some of you have had similar problems and can contribute some further info/
