Eberspacher - second on/off switch
Cardo
3 Oct 2005
In a plastic tub!
www.yacht-tinkerbell.co.uk
Our Eberspacher has one of these controllers in the saloon:
Does anyone know if it's possible to add a second controller to the system? It doesn't need to be anything fancy, even just a push button to start the Eber would do.
I was thinking maybe splicing a push switch into the appropriate wires to the controller. Would that work?
Or a second controller altogether wouldn't go amiss. Just something so we can turn the Eber on from the master cabin! :D
Anyone have any tips?
From memory, it ought to be possible, IIRC it is only one wire taken to the +ve that switches the thing on.
You might need to make sure the thermostat/controller box did not object to having its output taken high by the external switch, so it might be best to buffer the output with a relay, rather than just slapping a switch in parallel.
see the for sale section
