Slinky Spring
I currently have a rotary rheostat type control on my eberspacher D2. I have a problem because the heater is fitted in an enclosed space. The heater runs fine for a while then shuts down. I believe this is because the unit is sensing that the incoming air is warm enough(because the enclosed space is warming up) and the internal detector shuts it down. I therefore think I need a controller that has a built in thermostat.
My question is does the mini controller have a thermostat or is it just a more modern version of the rotary switch I already have. I have bought one of these already but may stick it back on ebay if its not the right one.
Some posts on here have described the mini controller as a thermostat but the technical specs do not seem to suggest that this is the case.
http://www.eberspacher.com/downloads/technical-documents/d9283017.pdf
I suspect the unit I require is this one.
http://www.pfjones.co.uk/eberspacher-digital-controller-80110003.html
Any advice welcomed
Any advice welcomed
