TonyS
I have tried twice to post this on PBO and nothing appears under the heading so this is a third try on a different forum.
I have just run my secondhand DILC on the bench and it works well. I was surprised at the high heat output. I have two questions.
1. Coming from a vehicle the input fuel line is equipped with a 2mm black plastic pipe. My fuel tank has two additional rubber plugs in the top(besides the engine offtake) that have 8 mm plastic elbows inserted and an 80 mm x 10 mm clear plastic pipe joining them. I assume this is to connect the heater standpipe. What bits do I need to connect the fuel pump. Should I buy some 8 mm copper pipe and use that as a standpipe through one of the 8 mm holes in a rubber plug. If so what is the preferred method of blocking the other plug. I hope someone out there has been through this and found a good solution.
2. I have a rotary knob to turn the heater on which has a LED in the middle and 4 positions. I plan to use this as the on/off control. But how would one mount it. The body is 40 mm in diameter. The only way I can see, as there is no additional shaft length, is to make a 40 mm hole in a ply bulkhead and push fit it. What do others do. I hope someone can help.
Tony
<hr width=100% size=1>Tony
Tony
