toad
I have a Eberspacher D2 in my van that has been playing up for the last two winters, It will start properly get up to full heat then after six minuets it will start slowing down in stages till it is just blows a slow cold air flow. This has a seven day timer with a diagnostic function but no codes present. There appears to be plenty of fuel although I have no way of measuring it, the combustion exhaust and air inlet are clear as is all the ducting( I disconnected the ducting to make sure). Looking at the manual on line I am thinking along the lines of ether the overheat/flame sensor or the inlet air sensor. The only problem is I cannot find the inlet air sensor and was wondering if the overheat/flame sensor is combined with inlet temp sensor. I did try to test the resistance of the overheat/ flame sensor but had no divisive results but that might be me. Can any experts confirm my diagnosis and confirm that the sensors are combined or not.
Its getting cold, I am getting old and I don't want another winter with no heat in the back of the van.
