Ben998
- Joined
- 3 Nov 2004
- Messages
- 153
- Location
- St.Lucia today, Martinique asap!
Hi All,
Another Eberspacher question, sorry! Ive read through a few of the historical posts, but I haven't found a definitive answer.
Im going to fit an Eberspacher heater in the boat, but should I be using copper fuel pipe between the fuel tank and the fuel pump, and the fuel pump and the heater in order to be compliant with any boating regulations?
It would appear from the instruction manual that the internal diameter of the fuel line between the pump and the heater is 1.5mm, and the internal diameter between the fuel tank take off (2mm internal diameter) and the fuel pump is a maximum of 5mm if the fuel pump is level with the bottom of the fuel tank, but the instructions don't state if there is a max internal diameter if the pump is mounted up to a maximum of 1m above the bottom of the fuel tank (hope that makes sense), they just state Fuel Plastic Pipe. Im assuming that this has to be no more than 5mm internal diameter as well, whether its copper or rubber/plastic?
cheers,
Ben
cheers,
Ben
