stu9000
I serviced my eber airtronic d4 for the first time a couple of weeks ago.
Sometimes it would fail to start and billow white smoke.
I think this was as much to do with the leisure batteries being below 12.8v but I read a sooty gauze is a common cause. So I removed the unit and replaced the burner gauze. It was quite gummed up.
In removing the unit the aging exhaust pipe cracked. I replaced it yesterday and added a silencer.
Works well once started but on start up some white smoke seeps out from the joints of the exhaust.
Where the pipe meets the unit.
Also where the pipe attaches to the silencer.
I have a particulate sensor and monoxide sensor on the boat but I'm not that keen on seeing exhaust gasses being sucked into the air intake.
Jubilee clips were used to attach the pipe. The pipe is the correct diameter.
The exhaust isn't restricting flow.
I'm going to try tgetting a better seal on the joints with heat proof aluminium tape.
Maybe I need to disassemble completely to see how much coking up is in there but it runs fine after about three minutes.
Any thoughts or suggestions?
