Eberspacher ducting - original or aluminium?
sailorman
21 May 2003
Here or thertemp ashore
Talk with Dave 2468, or what ever the numbers are. he will advise & his base near to you.
i had the solid stretchy stuff, DONT get the thin coated stuff with the spiral support, it is intended for a/c systems with low heat outputs.
Also consider the webasto insulated sleeve, expensive but superb. my heater has never been so good, even get heat & better volume out of the last outlet
