Murv
It fires roughly one time in 5.
When it does light, it runs faultlessly for up to a week (the longest I've run it for)
But, usually, it just blows white smoke.
The burner is clean, it has new gauze, gaskets and fuel pump filter, the only fault code is a time-out, voltage is good (currently running it on the bench straight off a large leisure battery on charge)
Changed the glow pin this morning, no change.
Measured the fuel flow from the pump and found it supplying about half of what it should (2.8 mls in 200 clicks)
Increased the flow until roughly 5.5mls in 200 clicks, connected all back up and it fired straight up. Shut it down again, tried to restart and it's back to normal (white smoke)
Any ideas?
Any ideas?
