dje67
My trusty Eberspacher D3LC has died. Ran for 20 minutes the other night, now won't start. It does nothing at all. Not a sound or attempt to run the fan. The timer green LED does click on when I try to start the heater, so the command to start is getting to the heater. I don't have a timer with diagnostics so can't interrogate it.
Wondered if anyone knows whether the ECU can be interrogated without the correct timer/controller (the one that has diagnostic capability built-in). I'm fairly sure the heater hasn't just locked-out, because I believe that the (Rev. 03) ECU module should clear any lock-out when it has been power-cycled. I've checked the resistance of the fuel pump, glow plug, flame sensor and over-heat sensor as per the Eberspacher workshop manual, so I'm fairly sure that they are all working OK. The motor itself shows a small resistance and generates a small voltage if turned by hand, so I reckon it is OK.
The photo is the ECU module - can't see anything obvious wrong with it, but don't have any means of 'asking it' what's wrong. It is a 251976510003 module.
Anyone repaired one? How did you go about it?
Ta.
Ta.
