Pete735
Just before coming off the boat on Sunday I thought I would fire up the Eber to check all ok. It last ran in March/April time this year.
On the "vent" position the fan cut in and ran fine. I then turned it to "heat", then was a noticeable click and then nothing. Several more attempts on "heat" produced nothing (no click), yet the fan ran when "vent" was selected. i checked the small fuse in the control pack and that was fine.
Battery was 12.6 volts, so well above Eber minimum.
I checked power to controller and it has 12v feed.
I checked the 2 associated relays and could not get power from any of the connections.
I think I am going to have to remove unit and try it on the bench, but does any one have any ideas? I pulled all connections apart several times just in case terminals were corroded, but no difference. I moved thermostat around a few times but that made no difference.
I suspect controller may be at fault, but just wondered if any forum members had any thoughts before I remove heater unit and try and bench test it?
