EBERSPACHER D2 AIRTRONIC WIRING ?
noname
5 Feb 2003
south coast
I have just purchased one of these off e bay and would appreciate help on connecting the unit .
It is an ex truck type that has an additional black control box which i believe to be a 1 hour timer?
I would like to initially fire it up to check operation of unit,on hopefully achieving this i would like to remove the 1 hour timer unit so it will run continually.
the black box has a white wire with a male bullet connector hanging out is this meant to be a switch wire if so where does it connect ?
I have been on the site but did not find the info i need.
any helpful sole out there that can steer me in the right direction?many thanks
i have used many different types of diesel blown heaters and all of them come with different switches and control boxes, however i have never used 1 thats on a 1 hour timer,more likley is the black box just has a simple on/off switch. of course i could also be wrong and have just not came across this type of control unit before.
Sorry i cant help with the wiring, if you get no joy on here you could try a local truck dealers for some free advice.
1-hour timer...
See the bottom of this page for info on the timer before you start installing it.
