Sticky Fingers
My new-to-me boat is fitted with a recently-installed Eberspacher D5. This is controlled by a microscopic push button thing with a display the size of a thumbnail. The amount of control is limited to on/off, fan or heat, and in the latter case, also target temp. It has I think one button that does everything plus a left and right that seem to serve no useful purpose other than changing the temperature, in which case I would have thought that up/down would make more sense. Impressive it is not.
I’d like to replace this My Little Pony / Fisher Price controller with some other thing that has the following key characteristics:
Compatibility with the D5
Large enough to detect with the naked eye
Buttons for each function
Big clear display that’s readable at a glance without a microscope and that tells me actually what’s happening
Programmable Timer for when things should happen
Fan speed control
Remote access so I can program it, or switch it on/off from my phone
The Eber catalogue appears not to contain anything suitable, but as it was written by a German product manager maybe I’ve just read it in the wrong order. Changing to Webasto isn’t an option either on cost grounds, also the D5 is nearly new and works ie heats, perfectly.
Anyone with knowledge on the subject who can help will be most welcome to suggest a solution.
Fan speed control
