fifer
I have an Ebersbacher D3L that's started having a few issues.
It has decided that it can try to start up on its own, even when the control dial is set to off. When it does this, it doesn't quite manage to fire up (you can hear clicks and a fan and there are a few wisps of white smoke from the exhaust) and then goes dormant. It will only try again if the ECU is unplugged to reset it. It was working fine last Autumn. This problem has only appeared in the last month.
I had been thinking about opening it up to give it a very basic service anyway.
Is this likely to be an ECU problem? If it is, is it worth trying to source a new one? Or should I be thinking about replacing the lot given the relative costs and age?
