pappaecho
I need some advice regarding this unit. When I bought the boat last year the surveyor flashed up the heater without problem. During last winter we disconnected everything from the fuel tank which was extensively cleaned. I did not commission the heater.
Today I tried and it flashed up OK on cool ( fan only) When i switched it to heat, it worked breifly and blew the fuse. On inspection the fuse ( 8amp) was blown, and should have been 15 amp as per he manual. It then flashed up briefly and the exhaust elbow got warm, but it then stopped. According to the manual, the system needs to be switched of and then on again, to purge the system. When I did this the fan system stopped working, so that there are two working LEDs but no fan working.
It seems that the diesel line has got air in it, and so how do I purge it manually? Is there any sort of reset, to explain why the fan system is not working. ( as I understand there are two fans, a heater fan which blows hot or cold air, and a combustion fan, which is controlled by the control unit. I am referring of coruse to the heater fan, which is now not working.
Any ideas/
Any ideas/
