mattonthesea
Am I right?
As far as I can work out from the GFS 500 depth and Surface Pressure chart forecasts the Jetstream is likely to stay to the south of us in GB. The low pressure systems will keep south and there is a high pressure over Norway. As the lows come in there will be two occasions where the high ridge between them will be squeezed into an omega before isolating the tip. The tip will then join forces with the high over Norway and continue to bring the wind from northern Scandinavia. While the omegas are in place the wind will be brought across from the Balkan areas. At the same time there will be an East West split where the lows bring just a hint of warmer air up from the south west to the West Country.
Any Met experts out there please tell this Met Geek that I'm wrong!
