dunedin
We have a few minor chips in the gelcoat around the cockpit, the usual results if knocks from winch handles etc. Mostly very small, but often quite deep.
What is the quickest and easiest way of filling? "Proper" gel coat is too thin to fill the depth, and I don't have the time (or warm weather) to fill and cure lots of layers.
Previously have used Plastic Padding gel coat filler as a quick and easy means of doing this - and used Humbrol model paint to match the colour. But recently the paint colouring has inhibited the setting (have they changed the formula). Is there another better solution for creating the cream colour with Plastic Padding ?
Or is there a better solution that will fill 1-2mm deep by similar width holes in one application, and will set reliably at temperatures below 10C?
NB Purists please look away. This is about preventing water ingress and getting a reasonable match. Our boat is about all year sailing and reliability, not perfection of appearance
