esheridan1
New Member
Hi, I have a steel hull boat and when I took her out of the water I discovered that the anodes had almost disappeared. My initial thought was that I have a bad earth and potentially a faulty piece of 240v kit on board causing the anode corrosion, but after inspection to my surprise that doesn't appear to be the case. The 240v mains earth appears to be totally isolated from both the battery negative and the steel hull. Therefore my logic cannot understand why the anodes are being used as a path to earth. I am very tempted to bond the mains earth together with the hull and battery negative. Any ideas?
As a side issue which may or may not be related, I get through a battery almost every year with very little usage made of them. This could be because my charger is not very intelligent and is cooking them, but I do wonder if it is related to the earthing issue.
Any help would be much appreciated.
