Got this from the site listed below
Wire Construction
DYFORM is the high performance wire strand which has a higher modulus of elasticity, offering the user less stretch and greater strength when compared with conventional wire of similar size.
Dyform is manufactured from D shaped strands that allow a higher cross sectional area to be achieved for a given wire diameter. This makes it approximately 20% stronger although also heavier. It is important to ensure the fittings (rigging screws etc) are also specified correctly to make use of the additional strength.
The outer strands of Dyform are flattened on the outer side so make the wire smoother, i.e. more nearly cylindrical. It effectively reduces the diameter of a given strength of wire, being part way between conventional 1 x 19 and rod rigging.
I haven't lived with it (having given up on stays) but when gripping a large diameter dyform stay, the edges of the strands feel sharp. It probably doesn't affect chafe of sails but I wonder if it wears sheets that rub across it,
I was told by the spar supplier, wire supplier and others that it tends to chaff sails much more than 1/19 and in most instances unless racing at high level the extra cost can not be justified.
