syd
Would one duff battery out of a bank of four cause you to lose all DC power?
I went down to the boat Monday with the intention of turning it around. Engines turned over slow, lights were dim, so put charger on for twenty four hours. While charger is on all the lights and pumps worked as normal but not enough power for engine crank. Turn the charger off and all goes dark within ten minutes. Disconnected the batteries and tested them one by one. Three are showing 13 plus, one is showing 9 and dropping. Would this one battery cause these symptoms? I've checked all the earths and connections, all seem fine. The batteries are in two banks of two. There is no isolator switch that I can find that normally allows you to select one two or all. I've ordered a new battery to replace duff one which is due to arrive on Friday(tomorrow).
Your thoughts on this would be greatly appreciated.
Syd
Syd
