cyrilslugg
Active Member
Some advice please! I went out into Langstone Harbour today to 'swing' my new NASA digital compass. I did as the instructions (slowly rotated the boat clockwise thru 360 degrees) and sure enough all seemed to work ok. As a final check I then aligned the boat's heading with a transit which showed on the chart as 55 deg. The digital compass showed my heading as 80 degrees. Both my normal boat and hand bearing compasses confirmed my heading as 55. I then checked a variety of headings between the compasses. The digital agreed with the 2 analog compasses for headings 0, 180, 270 degrees and all points between, but showed differences of 10 - 25 degs on headings between 0 and 90 degs. The 2 'normal' compasses were always in sync and correct to within a few degs of each other. I'm baffled or am I missing something (like a brain)?
