Dave70
Hello,can anyone tell me what amp cable i should use for dual trumpet horns,12 volt 9 amps Cheers Dave
Surely it depends on how long you intend to blow the horns? One of mine went AWOL recently so now just one horn, cable looks pretty weedy. Can't see a problem when usage is infrequent.
On that length of run 2 mm2 cable will give you approx 5% voltage drop,which is acceptable.
could i ask what 2mm2 cable is in amps.
Three bags of sugar. Or half an hour.
(ie, the question is meaningless because the units don't make sense.)
Gosh you're being harsh on the OP. Not everyone understands the details of power dissipation along cables....
Thanks for info. could i ask what 2mm2 cable is in amps. cheers Dave.
To give you the straight answer you are looking for
2mm² would be rated at about 20 to 25 amps but as said you should be able to buy it as 2mm² or 14 AWG
http://www.power-store.com/?id=69
http://www.furneauxriddall.com/acatalog/Cables.html
