iangrant
Thanks for all the posts - Well, I think I understand the wiring now, hanging upside down a lot etc.. etc..
Spent a while last evening and checked the mechanical fixing of the alternator and the wiring.
Mechanics all OK, just off to buy a fan belt to fit - Ha Ha. and a new velo alternator
Wiring -
6 Domestic batteries, 2 engine -
There is no domestic draw from engine batteries, they are completely isolated. **
The port alternator is as nature intended - wired directly as a dedicated supply to the two engine batteries.
The starboard alternator is wired through a 1-Both-2 switch with it's output connected to the common. So it is switchable 1 (engine) - 2 (domestic) or both..
So ** if it is switched to both there is an emergency domestic draw from the engine battery, or charging of both banks.
There are two sterling alternator controllers ready to be connected, but I'm reluctant to take apart the 200 quid 90 amp alternator Starboard to solder a field wire to the brushes!
I may look at the Veleo alternator replacement one with a view to connecting up proper like..
The question still arises - if I connect the two alternators i.e switch to "both" with both alternators running - will they go bang?
All great fun
Ian
Wiring -
All great fun
Ian
