pau1gray
We have two vessels berthed on the same pontoon SS is fitted with Simrad RD68 and MS is fitted with an ICOM M241. I have tested the DSC options on SS using my own set on my boat and that all seems to work OK.
I have programmed the MMSI into the ICOM on MS today and can't seem to get it to make an individual call - I have checked, double checked and even got someone else to check that I've put in the correct number, so I'm happy on that score.
If I try and make an individual call to SS, when I follow the instructions through in the manual i.e I select Individual Call, Select SS from the list or type in the MMSI of SS, select the channel to chop to and push enter it say individual call ready press enter again to transmit the call - it seems as if the radio switches off then switches back on, on Ch70 and is waiting for he acknowledge. SS does not receive the Individual Call ?????
If I try it the other way and get SS to call MS then the DSC is received on MS but the acknowledge is not received on SS (again MS radio goes blank for a second or two when I try and acknowledge the call) The two boats are only 20 m apart.
It would seem that any attempt to get MS to transmit a DSC call request causes the radio to reboot!
Have any experts on here got any clues?
I know that DSC is the bane of some peoples life on here but we want to check it's all working on the two boats in case we need it one day
