Finesse
Active Member
I have recently purchased a Cobra Marine MR F55EU marine VHF - DSC set and would like to connect a GPS to it. I currently have two devices, a Magellan GPS 320 hand held GPS and a Fortuna GPS receiver Model No. US. It would be my preference to use this latter device, the antenna, if possible but it is fitted with a USB connector. If I were to cut the plug off it and connect it to the plug supplied with the set, would this work? I am concerned that this device draws its power from the computer via the USB. With the Magellan device, this has an external output lead, with a serial connector which I use in conjunction with my PC for electronic navigation. If the antenna is not suitable, would it be OK to cut this plug off and connect to the VHF with this? Any help or advice would be much appreciated
