roaringgirl
I've recently re-sealed the saloon windows. I'm very happy to say the butyl tape has worked a treat. There is a horizontal beam in the hull about 60cm below the window, which forms a small shelf. The side of the hull and the shelf are covered in some kind of foam and then the foam is covered with the usual thin carpet stuff. Now there's no more water coming in, I'm hoping to dry out the foam insulation where the water has been gathering at the point where the shelf meets the hull.
I've had the dehumidifier on max, blowing dry air in that direction for 48hrs, but it's still damp. I do not want to open the can of worms that is peeling off the insulation. Does anyone have any tips or tricks for drying it in-situ?
