dry powder lubricant
Can anyone advise where to go (shop, not online) in UK for a powder lube I could use on the mainsail slugs and mast groove, sheet pulleys, etc? Is any brand/product better than another?
I used to use PTFE spray from the chandlers.
Then my small son cleaned the wooden floor of his bedroom with pledge thereby creating a completely frictionless surface. I discovered it works brilliantly on the sail slides and doesn't accumulate and gum up like the ptfe spray.
Worth a try and nothing to lose!
Pledge will probably contain silicones, which are in WD40 and other lube sprays. Smells nicer though.
thanks all
I'll try Pledge but I'm still thinking about Scotty Tradewind's answer........
"putting ptfe lubricant or similar into Google throws up suppliers"
..... does Google need lubricating ?
